Quote: I like to check the simple things first. Stock gauge or mechanical? Have you tried a different gauge or sender unit? Stock pan should hold 5 quarts of oil. I always put in 6. 1 for the filter.
Incorrect. A stock pan holds 4 quarts of oil, and one for the filter. Page 9-98 in the specifications section, of the 1970 factory service manual.
