Yup, I used that setup. I got the PA-4 pump with the kit.
I had to shorten it a bit to fit, and turned it so the tray was parallel to the front of the tank. (Otherwise the fuel would empty out the hole when accelerating)
The stock sending unit fit fine, so saw no reason to change it. I clipped the supply line for it inside the tank. If need an extra vent, I was going to use that for it.
