Are the heads ported and what rpm do you trap at now.. and are you happy with the rpm... do you want to go up in rpm..which you will unless you change gear ratio
yes they have been 346 on intake and 236 on exhaust or somewhere around there sheets in the basement...shift at 6500 rpm going thru traps about 6700 rpm
At what lift was the max flow... you want to exceed that lift to utilize the max out of the head
700 lift they were ported by Nick @ compu flo. my thinking is the current cams duration is a little high for my comp ratio even though it seems to be working good just trying to tweak it as much as possible....time in my sig is with good air
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
