Thanks for the reply, just looking for suggestings because I believe that there is more left in the car and I want to get the most out of it. I can tell u that the bottom bar is 2.5 degrees down and the upper is 9.8 degrees down. It has an 11.5 inch spred in the rear and 8 inch spred in frt. Plotting it out puts the IC at 102 inches out. The motor sits back in the car and the weights are 1320 lbs in the frt and 1430 in the rear. 727 trans and 4.88 gear with a 470 ci low deck. Thanks for your time.
66 Dart GT " Rat Racer"
