Strange struts on the frt set as loose as we can get them. Afco da's on rear. When we make adjustments to the shocks in the rear it shows up in the 60' times. I must say my son and I are not real happy with the struts. Thinking about having them revalved.
If I remember the 60' time on that run in the pic was 1.32 and that was the best it has ever done . That weekend every pass was in the mid 9.80s .
It might want the shorter IC... thats the thing with
cars... nothing is the same... my setting wouldnt
most likely work for you... just start trying but
move the IC back to about the CG point.. it will
most likely like it just behind the CG... testing
is the only way
