Quote: And there you have it... Just replace all the tires when you change the vehicle's battery and you'll always feel good about the ride...Just a reminder like changing the batteries in the smoke detectors when you set the clocks back every year...
Just sold my `04 ram with the original battery still working fine. How about your brakes, are they important? If they are you would need to change any rubber brake lines also, ditto fuel lines and anything else rubber that could cause a breakdown in the middle of a busy highway. Up here in the rust belt steel lines rust so I guess all the steel lines in a vehicle should also be replaced at the same intervals - see where this is going?
