If I understand the OP, there are no valves of any sort in his system, the front m/c line feeds the front brakes, the rear feeds the rear. The rear cylinders are smaller and fill before the fronts. With nowhere for more fluid to go, the master can no longer move and subsequently the fronts get no more pressure.
