Thanks Big Inch. It went 11.17 on 452 heads with the same .575 solid roller cam i'll run in the stroker. Only difference it had 13:1 compression on that pass. I'm hoping the extra 60 inches and better flowing heads will make up the difference. Can't wait 'til Spring!
