Dave,
It will probably be a month or so, I went thru BGR and not direct, so most of the parts should be on order, then I need to finish paying for it all and go get them...But yes, I will post flow numbers...He had a set there, and I liked them. They are far lighter than my 426-1 heads and will make the engine 1" narrower over the larger 426-1 heads. I will also be able to run T&D rockers if I so choose...
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
