This is TBI or MPI? If it's TBI you can check the injectors with a timing light and see if they are firing, and whether they have a good spray pattern. Code 45 will always show up when equipped with a 3 speed auto, disregard this one. My Ramcharger had EGR problems as well, probably could have been cleaned but I replaced it. That will definitely cause some bad running issues. Start with the free things, EGR can be cleaned with carb cleaner.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
