Quote: heater core is leaking or ac drain stopped up
Neither is the problem! I have the same issue since doing my intake pan, It only has air in it. My truck didn't do it until I done the intake. Now it does. I need to get the air out as well. And I haven't lost a drop of coolant so I know it's not leaking.
well i just had my heater core replaced because it was leaking and doing the same exact thing...
