I'm going to check the cooler line pressure when the motor is back in I'm running 5/16 and a fin style cooler with -8 adapted down to -6, we can clearly see the crank has rubbed the back side of the mains thats how bad it pushed forward. I did some reading and the cooler pressure should be 5 to 30 PSI.
