Quote: You meen the blue plastic male fittings that screw into the MC with the 2 short black hoses (the bleeder kit) that it's bubbling on/around the threads on one of the blue fittings? If so tighten it more, if that ain't it holler
I made up a set of steel bleeder lines using an old set of m/c to distribution block lines I had sitting around. They seal up better than the plastic kit and no hoses to jump out of reservoir. Bent them so they almost touch bottom of the bowls.
