On a dual-plane manifold, a 042 shooter seems quite large. As others have mentioned, the pink cam may not be the best for a street car since it is lazy in lift right off idle. I would suggest changing the pump cam first, and then come back down on the shooter. Every setup is slightly different. Try an orange cam to start. I suspect the shooter can come down into the range of 031 with the right cam but change one thing at a time. In my opinion, the cam is the more important of the two on a street car.
