I have may runs going through the traps with a single pickup deal at 7800 rpm. 528 stroker.
Sound like a double line pickup is overkill for most applications. As long as the pressure stays up where it should be, everything is a-ok. I think the to line systems stand a better chance of losing prime anyway. You could also use a swinging pickup with just one line instead of two.
