Are you talking about the same dealer installed in-tank pump that was put on my '01. Those things are just as bad or worse than the original block mounted pumps. 3-5 psi at idle, 0 as soon as you step on the throttle.
original post involves an 03. apples and oranges to your 01 fuel system.
