Are you talking about the same dealer installed in-tank pump that was put on my '01. Those things are just as bad or worse than the original block mounted pumps. 3-5 psi at idle, 0 as soon as you step on the throttle.
original post involves an 03. apples and oranges to your 01 fuel system.
I understand that, but I was under the impression that they still used the same type of lift pumps though. Or is the in-tank pump you're referring to different than the dealer installed pump that was on my '01? Only reason I bring it up is b/c mine was junk and I've never seen or heard anyone said they were good pumps?
