Thanks for the good info. The FASS with good filters was significantly cheaper than the dealer "in tank" conversion, so I installed the FASS (T D08 095G) Titanium Series Fuel Air Separation System. Rust is a non-issue in the desert so I hope it will last. Anyway, its quiet and it solved my "long crank" issue.
