Quote: has it idled rough since the timing belt change? it may be off a tooth.
I had the same thought, but from what I have read, one tooth off is enough to throw a code. It still has good "power" (by Neon's standard), starts quickly without a fuss, etc.
It had a little shake before, but the motor mounts were shot, so I probably wasn't feeling it....
I can live with it.....it's just one of those little things I wish I had the answer to...
