I am at a cross roads and the little Eddy Pump I have gets me thru the 1/8th mile, but pressure really comes down after that, so its time for properly sized one....We are running 512 cubes and 9.80's making around 730hp on 93 octane..
Been looking at something that is easy on power usage as well as long lasting and preferably a built in filter....
Looking at a magna fuel 275, but I really like the set-up I usually use which is an Aeromotive A1000....Both pull 8 amps with a carburator...The A1000 needs an added full return system....So I am on the fence, what do you guys use?
