Quote: I have been running the Kevco pan for 2 years and probably 200 passes at 6800 with a standard pump and I have had no issues so far. I just upgraded my fuel system and i will probably go up to 7000 rpm. Mine is 3.79 stroke 394 ci.
How much oil do you run in the pan? in the filter?
I have thought about keeping the kevko, running a standard volume pump again, and seeing what happens when I hit 7000rpm on a regular basis on nitrous...But I am worried at the same time about what could happen
I run 7 qts in my 30940 ( 8 qt pan ). Small oil filter to clear headers. I also run a windage tray. My block is filled, so oil temp can be an issue. I run an oil temp gauge as well as oil pressure. Go through the lights at around 7K and always good pressure. Running 7 qts is a SAFE quantity for me. You only get to run out once at 7K .
