I have a full width 8 3/4 in the car. If it is bent it was like that from the day I bought it cause it has been like that. I will be pulling it apart in the next couple weeks I will have to check it out.
Does it have a back brace... the OP the drive shaft
was disconnected and the rear rolled fine... a simple
way to check the diff is to pull both axles.. if they
pull out and slide back in easy the tubes arent bent
enough to worry about YET... but ANY car that hooks
CAN bend the tubes and they WILL be bent forward
