My car also rolls really hard. Ever since I built the car it has seemed really hard to push, like impossible by myself. I know when I try turning and rolling the spool binds up but even straight it rolls really hard.
My Duster did that from day one after having the 8 3/4 narrowed, turns out it was bent I ended up using two carpenter squares and measured out 15 inches from the center of the axles off of the axles flanges,no brake drums on the axles, front to back and then top to bottom My new cut down truck Dana 60 had the new ends welded on crooked also There on there square now The car pushes so much easier nowit is almost impossible to tell you the differences Do the basic measureing and go from there
