IMHO, if you run a tube cage I don't think you need to run the inner fender braces.
Here's a rough sketch idea of mine. Trying to route triangulation into the front chassis box. Trying to resist twist.
I don't think you could run a straight cross bar from the front k-member bolt area to the other side. I'm pretty sure that goes right through the crank pulley.
