I can see where the cam bolts were rubbing on the stock timing cover.
The first thing I'd be looking at is the length/thickness of the bolt head as that could be the issue. I've had allen head capscrews that hit the cover on install and had to use bolts with a thinner head. Just a thought before you assume the cam is walking.
