Get the teflon Comp Cam button for use with stock style chains and gears and stock timing covers.They are easy to cut down and trim for fit.They eliminate the chance of metal against metal issues and the more elaborate multiple piece buttons that can fall apart and cause other issues.
If you like drag racing, support your local track.
