Quote: "I don't consider 8 psi as low" Rebel at 2900 race weight that may be true but I know that my car at 3600 race weight is all over the track on top end at 8 psi. I don't think we know what his car weighs going down the track at 130 440 Brian how much does it weigh with you in it???
It weighs 2950 lbs. with me. I'll try a higher rear tire pressure next time at the track.
I checked the steering linkage and didn't find any play. It did seem like I had just a little in the front right wheel bearing. They look allright so I'll re-pack them. The front shock bushings look like they are falling apart, so it's probably high time I replaced them with a racing part. Any suggestions?
I ordered an algnment check tool kit, so I'll be taking a close look at the toe.
