Re: Need advice, plugs fouled, backfiring thru carb
[Re: RMCHRGR]
#1595145
03/29/14 09:22 PM
03/29/14 09:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
OK, got it running pretty well. I was even able to hot start it without too much trouble. It was running long enough that eventually I ran out of gas.
Once I got it running, initial timing was 26 degrees. Plate in the distributor is 13 so x 2 = 26. I remember now when I got it a few years ago I checked the timing and being surprised where it was at. Looked like almost 30 on the OE damper. Makes sense now.
As stated, I went to a hotter plug and it seemed to help a little. They were still getting a little carboned while fiddling with the idle but nowhere near as bad. I checked them at one point, no carbon at all. At least it was running and I was able to restart it.
A/F ratio was between 12.5-13 at idle. Seems like the A/F ratio is really sensitive to the idle mixture screws/throttle blades. Seems like a 1/4 turn can move the meter almost one point either way. With no load seems like the best throttle response is around 12.5. I'd like it to be leaner but I have not actually driven it yet.
Thanks for all the suggestions and tips. Took some doing to get to this basic point but I've learned some things for sure. I admit, I'm kind of a rookie at tuning. I was a tech for a while but I never dealt with carbs or distributors when I was working. I know it ain't rocket science but it can get confusing when you're chasing multiple issues.
Probably be back asking about bogs and hesitations soon.
Cool.. your getting there... I never worry about the AFR at idle... I set it so it idles the best it can and set the WOT to the best MPH... I only use my AFR to set the cruise... but once I get all the points dialed in(idle, wot and cruise) I take a reading so I can get back to it fairly easy.... and yes the mixture screws can be touchy with how much you move them.. what I do is once its warmed up.. slowly turn in one at a time till the rpm starts to drop then back them out 1/4 turn... go around the carb a couple of time to get it right... you might be lowering the curb idle(the idle screw) during this process but do it all a few times and it'll come right in... but the base timing is what you have to set FIRST.. thats a MUST ![](/ubbthreads/images/graemlins/wave.gif)
Entire Thread
Need advice, plugs fouled, backfiring thru carb UPDATE
RMCHRGR
03/19/14 04:10 AM
MR_P_BODY
03/19/14 04:49 AM
RMCHRGR
03/19/14 05:04 AM
MR_P_BODY
03/19/14 05:12 AM
RMCHRGR
03/19/14 07:57 PM
camastomcat
03/19/14 08:11 PM
roadhazard
03/19/14 08:39 PM
GTX MATT
03/19/14 09:37 PM
RMCHRGR
03/20/14 04:40 AM
RMCHRGR
03/21/14 03:56 AM
RMCHRGR
03/29/14 03:13 AM
MR_P_BODY
03/29/14 03:34 AM
RMCHRGR
03/29/14 03:51 AM
MR_P_BODY
03/29/14 04:02 AM
RMCHRGR
03/29/14 04:25 AM
MR_P_BODY
03/29/14 04:52 AM
B G Racing
03/29/14 12:30 PM
Chris'sBarracuda
03/29/14 01:23 PM
RMCHRGR
03/29/14 04:21 PM
Shoozy
03/29/14 04:24 PM
MR_P_BODY
03/29/14 04:25 PM
RMCHRGR
03/29/14 05:10 PM
DodgeCharger
03/29/14 05:56 PM
RobX4406
03/29/14 06:50 PM
RMCHRGR
03/30/14 12:07 AM
MR_P_BODY
03/30/14 01:22 AM
RMCHRGR
03/30/14 03:01 AM
sunroofgtx
04/02/14 08:30 PM
racingblues1426
04/02/14 08:48 PM
B G Racing
04/02/14 09:02 PM
RMCHRGR
04/03/14 04:02 AM
RMCHRGR
04/21/14 08:56 PM
joedust451
04/21/14 11:18 PM
RMCHRGR
04/22/14 02:40 AM
Cab_Burge
04/22/14 03:25 AM
B G Racing
04/22/14 08:52 PM
RMCHRGR
04/23/14 12:26 AM
B G Racing
04/23/14 08:40 PM
DodgeCharger
03/29/14 03:20 PM
