Re: Chassis Guys, a little help please?
[Re: loaderpro]
#1572342
02/05/14 02:11 PM
02/05/14 02:11 PM
Posts: 70 Lebanon, OH
Brad4406
Lebanon, OH
Obviously I should have done more research before attempting a ladder bar/coil-over suspension.
How do I determine centerline of the vehicle? Once it's determined, how do I find center on the rear axle and how do I ensure the axle is centered in the vehicle? I know I can't use the pinion as it is offset to the passenger side. That's why I thought if I just hung plum bobs off the rear frame rails and measured the distance to the axle flanges and made sure it was the same distance on each side that the rear would be centered. I already triangulated the ladder bar crossmember before welding, ensured the ladder bar brackets are evenly spaced on the ladder bar crossmember, and ensured both ladder bars are adjusted the same.
Didn't mean to scare you...You can hang the rear in that way, then build the shocks and ladder bars around it. The string set up will help you find errors in any particular set up. It just takes time to set up. If you recheck all of your measurements and they are inside the 1/8 tolerance you are good to go. If not then I myself would lay it out on the floor and see whats amiss.
You didn't scare me, I was just thinking that maybe this was a little above my skill level. However, I changed my mind this morning.
Entire Thread
Brad4406
02/02/14 01:54 AM
dvw
02/02/14 03:23 AM
Brad4406
02/02/14 03:52 AM
CMcAllister
02/02/14 05:06 AM
Brad4406
02/02/14 06:15 AM
dakotawilly
02/02/14 06:53 AM
Quicktree
02/02/14 10:22 AM
Brad4406
02/02/14 03:14 PM
PLUM BAD
02/02/14 05:39 PM
Brad4406
02/02/14 10:56 PM
MR_P_BODY
02/02/14 05:51 PM
dakotawilly
02/02/14 06:59 PM
MR_P_BODY
02/02/14 07:20 PM
Thumperdart
02/02/14 09:33 PM
dakotawilly
02/02/14 09:38 PM
MR_P_BODY
02/02/14 09:56 PM
Brad4406
02/02/14 11:01 PM
MR_P_BODY
02/02/14 11:22 PM
loaderpro
02/03/14 07:55 AM
CMcAllister
02/03/14 09:21 PM
Brad4406
02/04/14 09:22 PM
MR_P_BODY
02/04/14 10:01 PM
BJS racing
02/04/14 10:11 PM
BJS racing
02/04/14 10:13 PM
MR_P_BODY
02/04/14 10:22 PM
BJS racing
02/04/14 10:25 PM
loaderpro
02/05/14 06:22 AM
Brad4406
02/05/14 06:11 PM
Brad4406
02/05/14 06:12 PM
sbsatellite
02/05/14 08:45 PM
MR_P_BODY
02/05/14 08:56 PM
cudaman1969
02/05/14 09:56 PM
sbsatellite
02/06/14 03:08 AM
dvw
02/06/14 04:20 AM
cudaman1969
02/06/14 05:43 AM
Brad4406
02/09/14 05:01 PM
MR_P_BODY
02/09/14 05:14 PM
Brad4406
02/15/14 03:45 AM
Brad4406
02/15/14 03:47 AM
MR_P_BODY
02/15/14 03:51 AM
Brad4406
02/15/14 04:43 AM
MR_P_BODY
02/15/14 05:15 AM
Brad4406
03/02/14 03:12 AM
Brad4406
03/02/14 03:13 AM
Brad4406
03/02/14 03:14 AM
Brad4406
03/02/14 03:16 AM
MR_P_BODY
03/02/14 04:05 AM
MR_P_BODY
03/02/14 03:51 AM
Brad4406
03/02/14 04:01 AM
MR_P_BODY
03/02/14 04:08 AM
MR_P_BODY
03/02/14 04:17 AM
Brad4406
03/02/14 04:22 AM
