I use the factory tach with MSD. It requires the MSD adapter. There are several adapters offered... I picked based on my application and it was the lower cost version which worked.
The factory tach... well it does move to the right when RPM increases. Beyond that not so accurate. If you think the new board will help by all means try it. I will likely add a column mounted aftermarket tach.
