My car hates the cowl hood ![](/ubbthreads/images/graemlins/frown.gif)
I run a 5inch glasstek similar to Johns.I have tried 3 to 4 air pans,blocking this and that and different carb spacers and it dirty's the plugs after one run.
I also run a max effort carb that's 2.20 bore that's made for the most air you can throw at it.
Chris how does Butch Kemp run so quick with a cowl hood on the Mustang and its sealed to the hood
You need to look at the distance from the windshield..
close(about 1" to max 2")... this is mine but its
no A-body... I set this up up so I could hinge it
but I am thinking about making a slider on the back
opening to get it close for racing
my car hates it also.....glasstek 6"trimmed to 1.5" off windsheild as per instruction.factory 6pak hood worth solid tenth to 2 over the cowl.tried it with no hood also and went faster by about the same as 6pak through an aircleaner though in a dart.
