Quote: Blusmbl.....I agree......I never said that a camshaft doesn't effect the sound, or "lopeyness" of an idle.......All I'm saying is that you can take ANY motor with zoomies, and it won't have a "lopey" idle, unless timing is way retarded and it's very rich.....so, if I can prove to you guys that that's actually true, then it's the EXHAUST SYSTEM (including headers) and NOT so much the camshaft causing the "lopey" idle...AND THAT'S A FACT THAT I'LL WAGER ON
That's true, and I'm not taking your bet.
At the point where you have 8 injection stacks and zoomies, you've got essentially 8 individual engines on one common crankshaft. Discarding 2 strokes, I don't think I've ever heard a single cylinder motor with a choppy idle.
