Quote: So I'm on the edge of my seat any Radiator cleaning today? What's the plan? I need to know!
Ordered a new Champion Aluminum radiator from a member here who sells them. I'll pull the current radiator out of the car and swap it as soon as I can!! hopefully the trans cooler lines line up properly, and I can move my B&M tranny cooler over to the new radiator without any problems.. while I've got the old radiator out, I'll be sure to run a hose into the block and rinse out any crud that may be in there..
I do have a couple parts carbs (same model) out in the garage.. I"m gonna check to see if either of them have the richer metering rods ..
