Quote: When your car gets to 235 does it boil over? Buy the cap that was suggested to you about two weeks ago that tells you the temp. right on it to determine if it's a gauge issue. Or at the very least when it's 235 can you with it running slowly open the cap to see what's going on in there and/or use a meat type thermometer. Ron
I had that cap on it tonight... it also showed 230
Hey does anyone have a part# for that radiator cap with the built in thermostat? I want one...
