The HHR fan will work if you move the radiator forward and trim the back off. That being said, I decided against that, so I'm going to try the Derale 16217 17" High Output Radiator Fan. It's a 2 speed unit and should be here in a couple of days, so I'll see how it pulls. My plan is to use the HHR shroud. HTH, Steve
