Speaking of density, 318 and 360 used the exact same rods after about 72 and.... a 318 piston is heavier than a 360 piston.
The 318 has a shorter stroke so the weight has less affect on the imbalance and requires less balance weight and therefor can be internally balanced with a cast crank even though the bob weight is heavier.
I don't think so, Tim.
How stroke affects balance is more the distance the weight of the crank pin is away from center than what you are saying.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
