I am replacing a mid 70's 360 with a mid 80's motor. I noticed that the 70's motor has a big counter weight on the crank balancer that is missing on the mid 80's motor. I need schooling on this. The transmission I will use will come off the mid 70's motor. Can I assume there will be more external balance weights on the converter? Will I need a non weighted converter for the newer application? Thanks
Entire Thread
Subject
Posted By
Posted
Small Block Internal and External Balance Questions
