I am replacing a mid 70's 360 with a mid 80's motor. I noticed that the 70's motor has a big counter weight on the crank balancer that is missing on the mid 80's motor. I need schooling on this. The transmission I will use will come off the mid 70's motor. Can I assume there will be more external balance weights on the converter? Will I need a non weighted converter for the newer application? Thanks
All 360s are externally balanced...all need weight on the damper/balancer and all need weight on either the converter or the flexplate...
weighted converters from 360s are interchangeable.. as is the dampers.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
