Mine s a 92 with a 5.2. I'm not positive if the obd2 cars use the same impedance. Best way to find out is to check the resistance of the ones you have now. Just unplug the injector and use an ohm meter to check it. You may need the newer style low impedance injectors. The ones I took out ohmd at 13-13.5 ohms. The Ford ones I put in were 14 ohms. I just found this. Might be helpful. http://www.pavementsucks.com/board/thread-larger-injectors
