Picked up a set of Ford blue top injectors for my Dakota. I've heard that they will help pick up some gs mileage plus give you more power to boot. The truck is basically stock except for a polished TB (stock size), re-positioned crank sensor and the Ford injectors. I swapped the injectors this morning. Really a simple swap. Started it up and noticed it ran smoother and had better throttle response. I let it idle for about 10 minuets then took it for a ride. Right off, the "seat dyno" felt better. Throttle response was better, it felt a little peppier as well. The truck was getting about 14-15 around town. I don't expect to see a change this tank but hopefully I'll see an improvement by the next tank. I will keep yous guys posted with results.
