Took the RR out for a run, stopped at a friends house close by, he was thinking maybe the A/C compressor might be causing the stalling, by putting too much drag on the engine....too much pressure or something like that...it stalled again at his house as soon as I turned the a/c on and blipped the throttle...is there some test to check the compressor for drag on the engine or running too much pressure...
