Motor was rebuilt back in 05. I contacted the shop, but they couldn't help me as they only kept records for 5 years. It sounds stock, nice rumble but no lope, just smooth idle. No aftermarket items except performer intake, and 1405 edelbrock carb, and Pertronix Flamethrower 3. I did change the timming chain (CompCams) as the old chain had stretched, installed straight up. The stalling problem was before the installation of these parts.
Funny thing, when I first got the car it ran fine, a little sluggish, but it didn't stall, but it was running a points dist. with a vac, advance that didn't work. then it went downhill from there. It runs better with the Pertronix, but thats not saying much...checked for vaccum leaks after intake installed, but none found...
