Took the top off the carb, and surprise, one of the floats was hanging lower than the other one...reset the float, cleaned the bowls, took it out for a drive and it runs better, and didn't stall. The problem now is when going up a faily steep hill the transition from slowspeed to accelerating seems to bog down until more gas is applied, about 1/2 to 3/4 push on the pedal then it picks up.... maybe a spring change on the metering rod I'm thinking....will post results...
