Re: budget 440 build with rpm heads, good cam choice?
[Re: 70Cuda383]
#1513707
10/08/13 12:52 AM
10/08/13 12:52 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
You state no roller which is fine,but do you want a solid or hydraulic flat tappet? Power brakes a concern? Smooth idle and good vacuum a priority ? People tend to suggest a cam they use and like without knowing what your intentions are. Keith
the cam I had provided enough vacuum for my power brakes. I don't know how it would do if an AC compressor kicked on a idle though--if that would lug the motor down too much...
I was also running a stick shift, but with a mild stall, I think that cam will do fine with an auto
The cam you and Billy suggest would be a good one IMO.
RPM intake 4300# 3.73 gear AC/cruiser 2600 stall/ willing to change though. Vacuum carb.
Entire Thread
Spaceman Spiff
10/08/13 12:39 AM
Chris2581
10/08/13 01:25 AM
383man
10/08/13 01:28 AM
rck850
10/08/13 01:32 AM
MoparBilly
10/08/13 01:35 AM
70Cuda383
10/08/13 02:04 AM
pleasantk
10/08/13 01:41 AM
Re: budget 440 build with rpm heads, good cam choice? *DELETED*
Dunnuck Racing
10/08/13 02:11 AM
Spaceman Spiff
10/08/13 02:19 AM
Dunnuck Racing
10/08/13 04:00 AM
70Cuda383
10/08/13 04:41 AM
Sport440
10/08/13 04:52 AM
d7cook
10/08/13 04:56 AM
Spaceman Spiff
10/08/13 11:33 AM
Thumperdart
10/10/13 06:54 PM
Spaceman Spiff
10/08/13 11:36 AM
383man
10/08/13 04:22 PM
MoparBilly
10/08/13 04:25 AM
Twostick
10/08/13 04:30 AM
Dunnuck Racing
10/08/13 04:51 PM
moper
10/08/13 05:09 PM
Traven
10/08/13 04:31 AM
BradH
10/08/13 07:10 PM
Spaceman Spiff
10/10/13 03:28 AM
dannysbee
10/10/13 02:56 PM
383man
10/10/13 06:18 PM
bobby66
10/10/13 04:10 PM
