The sequence Cab recommended sounds backwards to me as well, but I recently heard/read somewhere else to do it that way. I always start furthest from the MC and work my way closer and I've never had a problem.
Pedal should be rock hard only slightly depressed, as described. You will never get these things anywhere near the floor once all setup correctly and bled.
Now I need to pin those needles, got to feel that heat
Hear my motor screamin while I'm tearin up the street
