What exactly should manula drum brakes feel like? I have manual drum all the way around on my 68 charger, and the pedal goes almost to the floor unless pumped. I adjusted the shoes at all corners and its better, to the point where the brake warning light does not come on...the rears were way out. It's a reman master cylinder, and I have all new lines (soft and hard) plus all new wheel cylinders. The proportioning valve was disassembled and cleaned. No leaks anywhere, is this just how it is?
