Before you spend any more money, put .028 hsmabs in all bleeds. Take carbs. off and adjust the transition slots the same and re-set the float levels. Then put .035 squirters in and go down, not up, from there on squirter size. Adjust idle screws 2 rounds out and adjust idle.
