Thanks, if you could get your 60 ft. better you would run nines easy. I know turbo cars run better on the top end. You should look into getting it a little lighter it would really pick up.I know that is easier said than done.Thanks..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
