2765 Hayden
https://board.moparts.org/ubbthreads/show...amp;Search=true
Edit: I guess I'm confused now, you wanted the jag clutch number, but then if I'm reading it right, you only want the fan? No clutch?
No I want the Jag clutch and the Mopar fan.. but I have yet to see a place where you can just buy the fan.
I get just a fan from the u-pull, I swap a 7 blade fan on all my junk.
I have found the last 2-7 blade fans on 78-80 AMC hornets, bolts right to the stock 78 truck HAYDEN HD max cooling thermo clutch.
for a 5 blade any 5th ave or dippy would have the fan blade to fit the jag clutch or the mopar viscus clutch.
