Re: Jag fan clutch #
[Re: Suregrip391]
#1488370
08/21/13 03:10 PM
08/21/13 03:10 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Not enough dumb comments...yet
Brookeville, Md
Related question; what's the solution to the VERY limited room to install the Jag clutch to the water pump?
Right now I installed studs (actually long hex set screws) with nuts but I'm really not filled with confidence with that solution.
thanks, Joe
pull the radiator out I guess.
If running a shroud, rad & shroud has to be in place or you will NEVER get the assembly back in and over the fan...
yes you'd pull the rad, install clutch and fan and any belts, then lay the shroud over the fan, install rad, move shroud back in place. Done that many times. That's how you pull the rad right? you remove the shroud...push it over the fan and remove it....
